CV axle problems
102,500 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
OPEBABAO
When I engage the gear in drive it does not move, but when I shake the gear stick it connects. This started after I changed the CV shafts.
Jan 21, 2019 at 10:09 PM
  • 55,710 POSTS
It sounds like you do not have one of the CV axles in the transmission all the way. HEre is a video to show you how to do the job so you can double check your work.
https://youtu.be/9OYxj9y3Zjc
Jan 23, 2019 at 4:05 AM
