First gear skips when releasing the clutch
2008 HYUNDAI I10
71,000 MILES • 1.1L • 4 CYL • 2WD • MANUAL
RUOKUOBEITUO SEKHOSE
My gear 1 usually slips while I release the clutch. everything seems normal while driving it doesn't come out to neutral... is it because of my gear cable?
Jan 23, 2021 at 5:18 AM
Most likely not. More then likely this is the clutch itself is failing as a result of the throw out bearing. This is what is responsible for engaging and disengaging the clutch when you press the pedal.
Here are a number of guides that will help with this:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
https://www.2carpros.com/articles/clutch-symptoms
https://www.2carpros.com/articles/throw-out-bearing-replacement
https://www.2carpros.com/articles/inner-workings-of-a-car-clutch
https://www.2carpros.com/articles/how-to-replace-a-clutch
https://www.2carpros.com/articles/pilot-bearing-replacement
If it were me, I would go ahead and replace the entire clutch rather then just parts of it. You only want to go in there once so I would just make sure everything is new.
We don't have a manual on this vehicle but if you want to, you can let it go and see how much more use you can get out of it. Once it starts to get hard to put it into first gear, you will want to go ahead and replace it so that it doesn't leave you stranded.
Jan 24, 2021 at 10:18 AM
