Failing to change gears when on Automatic mode
180,000 MILES • 2.5L • 6 CYL • AUTOMATIC
MAHEMBEB
Good Day
My car is failing to change gears when on Automatic mode but changing in Manual mode. Also failing to exceed 100km/hr on speed. Please help.
Dec 15, 2019 at 4:26 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It sounds like the most likely culprit is your transmission output speed sensor. The fist step in determining if this is likely would be to pull any trouble codes stored in the PCM. I have attached a link to our tutorial on retrieving trouble codes, please keep in mind that even if the check engine light isn't on there still can be codes stored in the PCM.
If you could find out if there are any codes and get back to us on your progress we can guide you further. We look forward to hearing back from you and thank you for using 2CarPros!
Dec 15, 2019 at 8:19 PM
