Gear box problem
166,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
PANDIYAN
Gear hold light is on and blinking all the time. when gear is in D gear does not shift to various speed.
Mar 26, 2018 at 1:32 PM
STEVE W.
  • 15,409 POSTS
That is the emergency mode. It can be caused by multiple issues. The only way to discover what is to use a dealer level scan tool to interrogate the transmission control unit and read what codes or faults are set. It could be as simple as a loose wire or bad sensor, or it could be internal transmission failure. The codes stored will give a map to look for the problem. (Oh, that car is actually a Daewoo Lacetti with GM badges, in case there is a Daewoo dealer nearby)
Mar 28, 2018 at 2:33 PM
