gauges not working
1997 PLYMOUTH BREEZE
123,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
OJ ZAYAS
no gas, mileage, tachometer, speedometer.
Sep 14, 2020 at 10:21 AM
4DRTOM
  • 467 POSTS
These gauges are run by a module that could be bad also a ground connection could be the issue. I attached a diagram to locate the all the grounds in the car and the fuse information for you to check out.
Here is an article about odometers for you review:
https://www.2carpros.com/articles/how-an-odometer-works
Let us know how you do.
Tom
Sep 14, 2020 at 1:40 PM
