Gauges not working
260,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
PANITSARA
i stop turn motor off and when i went to start it it won't. no power. so i checked battery and earth connect was loose so i tighten it and it started, but all dash gauges do not work but everything else does.
Dec 28, 2020 at 11:30 AM
I suspect there is a possible fuse issue. Let's go to the fuse panel and check the fuses using the guide below.
Unfortunately we don't have a manual on this vehicle as it is not offered here in the USA but if you found the ground loose then I suspect when you remove it or tightened it, there was a quick short which could have blown a fuse.
Let us know what you find with the fuse for the cluster and we can go from there. Thanks
Dec 30, 2020 at 5:26 AM
