Fuel gauge, temperature gauge, oil pressure gauge, and battery are not working
123,456 MILES • 3.8L • V6 • 2WD • AUTOMATIC
JACOBQF24
The speedometer and tachometer are still working. All the lights that should come on still come on. I checked the fuses and got really confused. the top for the fuse box under the hood doesn’t even match up with the fuse panel. It’s also missing half the fuses and relays as well. I got under my dash and checked them out a little bit but not much. I just need to where I should start solving this problem at.
Aug 10, 2019 at 3:39 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first fuses you want to check that controls the instrument cluster illumination are fuses #13,15, and 18. Here is a fuse checking tutorial:
I'll try to find you a fuse block diagram but check those fuses first.Hope this helps and thanks for using 2CarPros.
Danny-
Aug 11, 2019 at 1:21 PM
