gauge cluster not working
260,000 MILES
KOBI BORJAS
All lights turn on but speedometer, tachometer, gas gauge, oil gauge and temperature gauge. fuse 11 is perfect i can’t figure out the problem.
Mar 17, 2022 at 1:14 PM
  • 110,248 POSTS
Fuse 11 powers the seat belt switches. In the same fuse box, check fuses 1 and 17. When you check them, make sure there is power to them as well.
I attached the wiring schematic related to the instrument panel. Note Fuse 11 goes to the seatbelt switch.
Let me know what you find with the others.
Mar 18, 2022 at 12:27 PM
