Gauge cluster swap?
280,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
EARL91
  • 88 POSTS
What years are interchangeable for the vehicle listed above e 250 gauge cluster?
Aug 16, 2024 at 1:06 AM
  • 55,797 POSTS
For a 2005 Ford E-Series Van (specifically the E-250 model), the gauge cluster is generally interchangeable with models from the following years:
2003 to 2007 Ford E-Series Vans (E-150, E-250, E-350, and E-450)
Here is how to change the cluster out in case you need it. Check out the images (below). Please let us know what happens.
Aug 17, 2024 at 2:12 AM
PD8946
  • 0 POST
The information was incomplete. Instrument cluster need to be programed by a Ford dealer or some who understands the programming.
Mar 30, 2026 at 1:04 PM
  • 55,797 POSTS
If you are repairing your original cluster then no programming is needed. But, yes, if the cluster is from another vehicle or the programming/PATS setup so it will not communicate correctly with the vehicle and keys. Good catch.
Mar 30, 2026 at 1:08 PM
