gass pump
123,230 MILES • 4.7L • V8 • RWD • AUTOMATIC
RAFAEL MORALES
I mount the pump but didn't work. I take it off and jump it and works. Mount it back and don't work. I check relays and fuse, all good. Working now on cheqiing the voltage of the truck terminals.
In need of help.
Feb 9, 2016 at 11:42 PM
WRENCHTECH
  • 20,758 POSTS
So I guess you never tested for power arriving at the pump before replacing it?
Feb 9, 2016 at 11:47 PM
RAFAEL MORALES
Now I did , voltage is 0
Feb 9, 2016 at 11:49 PM
RAFAEL MORALES
I check first the relays and fuse
Feb 9, 2016 at 11:50 PM
WRENCHTECH
  • 20,758 POSTS
If the voltage was 0, why did you go ahead and replace the pump?
You do realize that only powers for 2 seconds when the key is first turned on and resumes when the computer sees a crank signal.
Feb 10, 2016 at 12:10 AM
RAFAEL MORALES
In the first 2 sec is a 2.0v then drop to .8v
Feb 10, 2016 at 12:26 AM
WRENCHTECH
  • 20,758 POSTS
Test it with the pump unplugged. It will be either battery voltage or nothing. Make sure you are not reading the fuel gauge.
Feb 10, 2016 at 12:41 AM
