Gasoline behind throttle body
168,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JBIRD#69
  • 7 POSTS
I removed and cleaned throttle body. I notice a pool of gasoline when I removed throttle body. Is that normal? if not what would cause gasoline to pool up there?
Apr 15, 2018 at 6:45 AM
Good morning.
No, it is not normal. that is an air intake system not a duel intake system.
it could come from a leaking injector or fuel coming into the plenum from the EVAP system from a bad purge valve.
Do you have any codes?
Apr 15, 2018 at 10:43 PM
JBIRD#69
  • 7 POSTS
yes, the codes are P2101 and P2110. I did not think that was normal.
Apr 16, 2018 at 6:08 AM
Okay.
2110 below are possible causes.
P2110
Item Description
Symptom/DTC P2110
Descriptor
Electronic Throttle Control - Forced Limited rpm
Probable Causes:
Electronic Throttle Control (ETC) Motor.
Electronic Throttle Control (ETC) Motor (+) Circuit Open or High Resistance.
Electronic Throttle Control (ETC) Motor (+) Circuit Shorted to Voltage.
Electronic Throttle Control (ETC) Motor (+) Circuit Shorted to the ETC Motor (-) Circuit.
Electronic Throttle Control (ETC) Motor (-) Circuit Open or High Resistance.
Electronic Throttle Control (ETC) Motor (-) Circuit Shorted to Voltage.
Electronic Throttle Control (ETC) Negative Circuit Shorted to Ground.
Electronic Throttle Control (ETC) Positive Circuit Shorted to Ground.
Power train Control Module (PCM).
Throttle Plate Stuck or Obstructed.
Apr 16, 2018 at 6:12 AM
Okay.
2101 below.
Looks like they are related to the throttle body.
why did you remove the throttle body?
P2101
Item Description
Symptom/DTC P2101
Descriptor.
Electronic Throttle Control Motor Performance
Probable Causes:
Intermittent DTC.
System Voltage Low.
Throttle Body Assembly.
Apr 16, 2018 at 6:13 AM
JBIRD#69
  • 7 POSTS
I removed throttle body to clean it because it was dirty when I inspected it. That is when I noticed a pool of what I believed to be gas behind it. I removed throttle body because I had a red lightning bolt indicator on dash board.
Apr 16, 2018 at 6:30 AM
Okay, did you have any other codes?
the most common failure for this is the throttle body itself.
Apr 16, 2018 at 6:34 AM
JBIRD#69
  • 7 POSTS
Yes, that is what I have read. I am hoping cleaning it fixes the problem if not I will replace. I am now trying to figure out why there is gas pooling up behind the throttle body..
Apr 16, 2018 at 6:41 AM
JBIRD#69
  • 7 POSTS
sorry, no other codes.
Apr 16, 2018 at 6:42 AM
okay, as I stated the purge valve may be pulling fuel from the tank. that is the only thing that makes sense.
Apr 16, 2018 at 6:44 AM
JBIRD#69
  • 7 POSTS
okay, thanks for the help. is there a test I can do for that?
Apr 16, 2018 at 6:47 AM
yes, remove the hose that goes back to the fuel tank. remove the electrical connector for the purge solenoid. start the engine and see if you feel vacuum on the line you removed. there should be no vacuum coming out of the purge valve.
Apr 16, 2018 at 6:50 AM
JBIRD#69
  • 7 POSTS
thank you for the help I appreciate it.
Apr 16, 2018 at 6:53 AM
no problem. we are happy to help.
Apr 16, 2018 at 6:54 AM
