Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Pacifica
Engine
Oil Pan
Gasket
Replace/Remove
How to replace oil pan gasket
2006 CHRYSLER PACIFICA
180,000 MILES • 0.5L
SANDERS5220
MEMBER
1 POST
Need to change oil pan gasket instructions.
Jun 25, 2017 at 12:34 PM
Experienced Mechanic
You will need to disconnect the battery and drain the oil before you begin. Also you will need to jack the car up.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here are some diagram (below) of what to do to check the oil pan on your car.
Cheers, Ken
Images (Click to enlarge)
Jun 28, 2017 at 10:03 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
