This could be a problem with the fuel tank pressure sensor or the associated wiring going to it. In the diagrams down below I have included a diagnostic troubleshooting guide for you for the fuel tank pressure sensor for your vehicle from the manufacturer. You will need to use a Digital Multi-meter [DMM] to go through this guide, so here is a link below, if you are unfamiliar with how to use one:
I have also included guides on how to find opens and short to grounds in an automotive electrical circuit. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Images (Click to enlarge)
Dec 2, 2019 at 11:09 PM
