Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
Tank
Gas tank not going to full
2000 TOYOTA CAMRY
175,000 MILES • AUTOMATIC
DCONNORS
MEMBER
1 POST
My gas tank only fills up to three quarters of the way. I have to press it about 7 times (It stops every time) to get it to full.
Aug 7, 2019 at 1:54 PM
Experienced Mechanic
Good morning,
There is air trapped at the top of the tank not allowing it to fill all the way.
The vent valve may be the issue as it is supposed to be open all the time so this issue does not happen.
It is part of the canister under the car above the rear axle. It is replaced as an assembly.
Image (Click to enlarge)
Aug 7, 2019 at 8:53 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
