Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Fuel System
Tank
Filler Tube
Gas tank filling
2002 FORD EXPLORER
200,000 MILES • V8 • 4WD
LMR
MEMBER
I have a 02 explorer with Filling problems. If replaced fill neck and hoses, vent switch and both charcoal canisters. What do u suggest for this
Jan 31, 2020 at 3:21 PM
JOETECHPRO
Experienced Mechanic
Hey LMR,
Have you checked the vent hoses for the carbon canisters are clear?
If the vent hoses are blocked at all it can cause a pressure build up in the tank as you fill up.
This is a fairly common issue on these vehicles.
Let me know how you go.
Regards, Joe
Feb 3, 2020 at 11:48 PM
LMR
MEMBER
Okay, thanks. I have not checked it yet. I have to finish an engine installation before I can work on this. Your suggestion is very appreciated .
Feb 4, 2020 at 7:43 PM
JOETECHPRO
Hey LMR,
No problem at all. Best of luck with the repair.
Keep us updated with your progress.
Regards, Joe
Feb 6, 2020 at 3:43 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
