Gas tank removal
11,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SEAN0399
  • 8 POSTS
Hi I have a 25 gallon tank on my truck listed above it is a k1500. It is an extended cab. I was wondering if it was possible to take that tank out and put in a thirty four gallon tank and would I have to change anything around? The tank comes with the pump already installed.
Feb 27, 2017 at 12:43 PM
  • 55,676 POSTS
Hey Sean,
As long as its a factory tank you should be okay except for the holding straps may be a little larger on the 34 gallon tank.
Best, Ken
Mar 2, 2017 at 2:17 AM
