then it is gone. i don't smell gas outside the truck.
Nov 25, 2019 at 8:52 PM
SCGRANTURISMO
✓Experienced Mechanic
Is your Malfunction Indicator Lamp [MIL] or "check engine" lamp illuminated? If so could you please pull the Direct Trouble Code [DTC] for us. Here is a link below explaining how to do this, if needed:
Please get back to us with what you find out and we can go from there.
Thanks,
Alex
2CarPros
Nov 25, 2019 at 11:01 PM
This sounds like you have an EVAP issue that is why the expert wanted to run the codes. To me it sounds like the charcoal canister needs to be replaced or a purge solenoid. Please run the codes and get back to us.
