Gas pedal stuck to the floor after cleaning the throttle body?
2008 TOYOTA YARIS
100,000 MILES • 4WD • AUTOMATIC
ISHMAEL.IGIRANEZA
I was cleaning my throttle body and now the gas pedal is stuck to the floor, when i turn the car on, it accelerates by itself.
Mar 8, 2023 at 8:17 AM
  • 110,244 POSTS
The accelerator pedal doesn't use a cable on this vehicle. It is an APP sensor. Nothing should have caused it to be stuck to the floor by servicing the throttle body.
Have you tried to pull it up manually? Could something be stuck forcing it to the floor?
Mar 9, 2023 at 12:49 PM
