engine has no acceleration?
14 MILES • 2WD • AUTOMATIC
WMYA567890
My gas pedal has started touching the floor when I'm only going about 30-45 and is accelerating very slowly.
Mar 30, 2021 at 11:30 PM
  • 55,647 POSTS
It sounds like you have a weak fuel pump, clogged catalytic converter or a bad MAF or MAP sensor. To be sure we should run the codes by checking out this guide:
We should also go over this guide as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Apr 1, 2021 at 5:07 AM
