Gas Pedal down to the floor while driving?
291,989 MILES • 3.0L • V6 • 2WD • AUTOMATIC
CHRISTOPHER IVAN ROEDER
  • 156 POSTS
As I was driving, I tried to pass someone and all of a sudden, my pedal sank down to the floor without any power at all. I luckily coasted to a stopping point and realized the cable from the pedal was not returning to its normal state just leaving me with extra slack at my pedal. is this an easy fix and can anyone help me with where the other end is connected? obviously near the throttle body but need more instructions than what I'm finding anywhere online. thank you for your time and patience in advance.
Nov 25, 2024 at 12:26 AM
  • 55,721 POSTS
Yep, it sounds like you snapped the throttle cable. I would get under the dash to see how it is set up and disconnect the cable. here is how the job is done while under the hood, and this tells you how to adjust the cable as well. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Nov 25, 2024 at 5:19 AM
  • 156 POSTS
I'm having problems finding the correct part anywhere that I know of or use on a regular basis. any suggestions?
Nov 25, 2024 at 12:09 PM
  • 55,721 POSTS
Not really, that will be a tough part to find, did you try ebay?
Nov 26, 2024 at 2:40 AM
  • 156 POSTS
Yes and a couple of Honda parts places price isn't bad until they charge you $60 to ship it lol... Could I possibly try one of those universal kind I think it's called Mr.Bracket, or something like that.
Nov 26, 2024 at 2:53 AM
  • 55,721 POSTS
Yep, that is the other option.
Nov 26, 2024 at 3:39 AM
  • 156 POSTS
So I bought a Mr gasket bracket and universal throttle cable and there's no instructions where to install the bracket or how to install the bracket any suggestions and is it even a good idea or should I just order the OEM throttle cable? Thank you in advance.
Dec 1, 2024 at 11:17 PM
  • 55,721 POSTS
I would order the OEM cable, the aftermarket unit can be a challenge because they are universal.
Dec 2, 2024 at 2:09 AM
  • 156 POSTS
Yeah, I just went to Honda and ordered it and actually was the same price as online and I'll get it in less than 24 hours not bad at all. I'll keep you posted and thank you for your time and help it's greatly appreciated.
Dec 2, 2024 at 2:46 AM
  • 55,721 POSTS
Sounds good, nice work it sounds like you have a handle on it.
Dec 3, 2024 at 1:09 AM
