After starting the car and pressing the accelerator pedal the car does not move
31,000 MILES • 2.4L • 4 CYL • AUTOMATIC
DEVAN1983
Whenever I turn my car on and hit the gas my car doesn't do anything.
Jan 8, 2021 at 6:30 AM
DANNY L
  • 5,648 POSTS
Hello, I' Danny.
It sounds like you might be having an issue with the accelerator pedal position sensor. It is a sensor built into the accelerator pedal. This is considered a fly-by-wire design and relays information to the throttle body and engines computer to control the engine RPM's. I've attached picture steps below for its location and replacement steps. I've circled the sensor in red. Hope this helps and thanks for using 2CarPros.
Jan 8, 2021 at 1:00 PM
