Gas pedal
173,888 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
WHAT IT DO
Gas pedal will not go down when pressed.
Jan 28, 2018 at 10:21 AM
Good morning.
Check under the pedal for anything blocking the pedal from moving.
Check at the throttle body for anything preventing the plate from opening.
The cable itself may be the failure as it could be seized internally.
Jan 28, 2018 at 9:47 PM
