Poor fuel mileage
133,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROB CARNINO
  • 7 POSTS
I filled my car up today. When i started it the fuel gauge read full and the computer said 345 miles to empty. I drove about 15 miles and the gauge dropped a quarter and the computer said 290 to empty. I have no full leaks. Any idea what this could be?
Thanks
Rob
Apr 1, 2021 at 12:38 PM
  • 110,248 POSTS
The idea that it changed that much is interesting. Were the 15 miles in town driving? I ask because if the overall average drops, so does the distance to empty. Also, what does the vehicle indicate for average MPG?
Apr 1, 2021 at 12:58 PM
ROB CARNINO
  • 7 POSTS
Yes, I was in town driving. I believe it’s 26 MPG.
Rob
Apr 1, 2021 at 1:13 PM
  • 110,248 POSTS
That is higher than I expected. Can you recall if that is what it was getting before?
Apr 1, 2021 at 4:13 PM
ROB CARNINO
  • 7 POSTS
It says 22.
Apr 2, 2021 at 6:53 AM
  • 110,248 POSTS
When fuel economy drops, check the basics. First, a plugged or dirty air filter can cause it. Also, if it hasn't been tuned up for a long time, that would be something to consider.
I would check the air filter first. Here is a link that explains in general how it is done:
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
If a tune-up hasn't been done for some time, it may help. Here is a link that shows in general how it's done:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Let me know if that helps. Also, let me know if you have other questions.
Apr 2, 2021 at 11:43 AM
ROB CARNINO
  • 7 POSTS
It a new engine all that gas been replaced.
Apr 2, 2021 at 11:51 AM
ROB CARNINO
  • 7 POSTS
No brand new only 70,000 miles.
  • 110,248 POSTS
Did this just start since the engine was replaced?
Apr 2, 2021 at 12:05 PM
ROB CARNINO
  • 7 POSTS
Yes.
Apr 2, 2021 at 12:12 PM
  • 110,248 POSTS
If it is running properly and the check engine light isn't on, chances are it is simply the result of a different engine. Keep in mind, chances are they reused the fuel injectors, intake, and other components which came with the new engine.
Since it is new to you, drive it a bit. Put a few hundred miles on it to see if it changes. If possible, let me know if there is a change.
Apr 2, 2021 at 1:37 PM
