Fuel line issue
205,000 MILES
MOLLY MULKEY
When i put the hose in the gas line from the fuel pump when I crank it the hose pop's off.
Aug 10, 2019 at 5:15 AM
Hi Molly,
Can you get a picture of the fuel line that you are having issues with? There are a couple different options and depending on which one it is, it will change the recommendation.
You can just post the picture to the post and I will get back to you with what you need to do. Thanks
Aug 10, 2019 at 5:48 AM
