Gas light coming on with full tank of gas
1998 DODGE STRATUS
135,000 MILES • 4 CYL • AUTOMATIC
LAB0415
The gas light just came on and car has a full tank of gas. The needle on the gage is moving continuously. Engine is running fine, but now it won't move. Was fine until 30 minutes ago.
Sep 2, 2015 at 8:01 AM
  • 110,244 POSTS
It sounds like either the rehostat is going bad, or there is a wiring issue to the sending unit. When you say it won't go at all, do you mean the gauge or the car?
Sep 2, 2015 at 12:14 PM
LAB0415
Well it is actually driving fine. In the state of panic my daughter didn't get it in gear apparently. but the gas light is coming on and going off and the gauge the finger is bouncing back and forth. she has a full tank of gas though. we are thinking that it is some sort of sensor. any suggestions?
Sep 2, 2015 at 1:40 PM
  • 110,244 POSTS
Most likely it's the rheostat on the fuel pump. That is what sends the level signal to the gauge.
Sep 7, 2015 at 7:20 AM
LAB0415
It was the fuel pump and filter. They were both original to the car! $420 later and she's back on the road again. Thanks for your help.
Sep 7, 2015 at 9:48 AM
