Changed fuel injectors. Now the gas is leaking in to the oil. Before change the fuel injectors the gas was leaking out the exhaust.
Jun 24, 2016 at 9:05 AM
✓Experienced Mechanic
Hey William,
It sounds like you might have a system ground that is off, if it all checks out the computer is bad because you have an injector driver that is stuck on.
