Gas leaking from the top gas tank, how to drop the fuel tank?
2002 GMC YUKON
35,000 MILES • 5.3L • V8 • AUTOMATIC
DATUCE
Which lines do I disconnect before dropping fuel tank? Please explain to me the steps to drop fuel tank I've never done any type of mechanic work before.
Mar 2, 2025 at 3:40 PM
  • 55,433 POSTS
Anyone can do car repair work, you just need to tools and the will, with instructions from us. Wear protective gloves and eyewear, here is a guide to help you lift the car up while using jack stands for safety:
https://www.youtube.com/watch?v=xLFn_bMkZc0
Also, you will need to drain the fuel out before removing the tank, use fire safety precautions as well, here are two videos to help you do the job correctly:
https://www.youtube.com/watch?v=Q5MH2gnyFH0
and
https://www.youtube.com/watch?v=VuGxQgWDP-0
Please let us know if you need anything else.
Mar 3, 2025 at 4:38 AM
