gas leak
75,000 MILES • 0.5L • V6 • AUTOMATIC
DEAN ANDRIACCIO
Leaking fuel underneath by driver side back passenger of car. filled tank then dripping started. Usually only have half a tank or less. It is a steady drip . Especially when car was running. Any suggestions of what cause could be or solutions?
Jan 21, 2017 at 4:03 AM
HMAC300
  • 48,601 POSTS
check fuel lines for a break/crack or hole. probably rusted through could be a rubber hose as well.
Jan 21, 2017 at 4:32 AM
DEAN ANDRIACCIO
Okay, I will. thanks.
Jan 21, 2017 at 8:43 AM
SATURNTECH9
  • 30,868 POSTS
With that new of a car it is probably a vinyl line leaking or the fuel pump it self. Sometimes the nipples right off the fuel pump leak.
Jan 21, 2017 at 11:40 PM
