When it does start, I can't apply too much gas because it will start to choke and shut off and backfire in the intake.
Mar 12, 2023 at 5:11 PM
✓Experienced Mechanic
This sounds like low fuel pressure but to be sure let's go over this guide and run the test. You can get a fuel pressure gauge test kit from the local auto parts store for cheap or free. Here is a guide to help you step by step and the instructions in the images below for your car. It could be a clogged fuel filter as well.
