gas in oil
240 MILES • 2.5L • 4 CYL • 2WD • MANUAL
JUDSON MILLER
I noticed gas in my oil. I checked fuel pressure damper on injection bar. No dribbles seems to run perfectly, fires right up. I noticed whenever I slow down for a traffic light it idles high for a few seconds then it idles normal again.
Any suggestions?
Oct 16, 2016 at 7:54 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole for high idle . fuel pressure should be 56-72 psi with key on only if it was near at least low number then it is a problem with pump or regulator if too high regulator gas in fuel may be leaking injectors or very short drives like less than ten miles all the time.
Oct 16, 2016 at 11:32 PM
JUDSON MILLER
10-4 thanks.
Oct 16, 2016 at 11:39 PM
  • 55,770 POSTS
Everyone has a small bit of gas in there oil because the engine burns gas. So it is normal, is the engine over full on the dipstick?
Oct 19, 2016 at 11:49 AM
