Gas gauge not working correctly
141,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
SCOTT2000SONOMA
The gas gauge jumps from full to empty while driving.
Nov 24, 2019 at 5:41 AM
Good evening.
This could be a bad connection at the fuel module at the tank, it could be a bad connection at the cluster or a bad cluster, or it could be a wiring issue.
I attached a diagram for you to view. start with the connection at the fuel module. That is the most common failure for this issue. Check the purple wire at the connector.
Nov 24, 2019 at 7:31 AM
SCOTT2000SONOMA
Okay, I'll check that out. thanks
Nov 24, 2019 at 8:22 AM
You are welcome.
Keep me updated.
Nov 24, 2019 at 8:31 AM
SCOTT2000SONOMA
I'm also having a temperature gauge problem jumping up and down quickly randomly but always returns to normal temperature. thanks
Nov 25, 2019 at 7:21 AM
Check the connector behind the cluster. That may be the reason for both issues. Make sure the pins are clean, tight and not damaged.
Nov 25, 2019 at 7:59 AM
