gas gauge fluctuates
18,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
KEITH BRIGGS
My gas gauge goes from full to empty. where is the relay fuse?
Nov 6, 2016 at 5:02 AM
HMAC300
  • 48,601 POSTS
there is no relay normally gauge fuses handle that. but it may be either a gauge bad or short in wiring or the sender. you will need a mechanic to scan for codes to find the problem it can be a dash which is digital and they do that.
Nov 6, 2016 at 8:04 AM
