1999 Chevy S-10 Fuel gauge wanders even when vehicle sittin
1999S10
  • 1999 CHEVROLET S-10
  • 4 CYL
  • 97,000 MILES
The subject line pretty much says it all. You can be sitting in the vehicle perfectly still and the fuel gauge wanders all over the place. I have had another problem with the check engine light coming on when the vehicle is hot on hot days. I am told the computer code says it is the "evaporative emission sensor" in the fuel tank. But I don't see how the two could be related. Is it the dash gauge, the wiring, or the sending unit in the tank? Or something else?
Friday, September 10th, 2010 AT 7:14 PM
WRENCHTECH
  • 20,761 POSTS
That is most likely a bad fuel gauge sender. They have a lot of problems with them due to the additives in the fuel. You can confirm it by just unplugging it and see if the wandering stops.
Friday, September 10th, 2010 AT 7:41 PM
