Gas gauge not working after replacing fuel pump?
1992 NISSAN MAXIMA
268,248 MILES • 3.0L • V6 • 2WD • AUTOMATIC
SOCALREAPERGIRL
Replaced fuel pump now gas gauge not working.
Jan 14, 2019 at 11:47 AM
HARRY P
  • 2,292 POSTS
The fuel pump has a float on it. That float goes up and down with the fuel level, and has a rheostat that returns a corresponding amount of voltage to the gauge. If the wiring for that float is loose, or if the float got stuck in position when the pump was installed, then the gauge will not be accurate. Try filling the tank with gas and taking the car for a drive down a dirt road. Doing so might jar it loose if it's just stuck. If not, drive it for a couple of days and then open the access door up again (if the car doesn't have an access door, then you'll have to lower the tank and pull the pump out that way). Pull the pump out and check the condition of the float and make sure that it moves the way that it's supposed to. Put it back in and make sure that the wires are super tight. Test it out. If it still doesn't work, exchange the pump for a new one.
https://www.2carpros.com/articles/how-a-fuel-pump-works - General information on the pump
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump - How to change a pump in general
Do some poking around and let us know what you find. We'll go from there.
Jan 14, 2019 at 12:51 PM
SOCALREAPERGIRL
Thanks, I will try that.
Jan 14, 2019 at 1:15 PM
SOCALREAPERGIRL
Got it fixed. it was a ground wire near the gas tank.
Jan 15, 2019 at 11:04 AM
HARRY P
  • 2,292 POSTS
Sweet! Glad to hear that you got it going. Please feel free to come back anytime and send your friends too!
Harry
Jan 15, 2019 at 12:21 PM
CAREYTOURAILLE
  • 5 POSTS
On the 2010 Corolla were is the ground wire is it under the tank cause I didn't see anything around the top were the pump is?
Jun 14, 2023 at 8:25 AM
  • 110,244 POSTS
I would be happy to provide you with wiring schematics, but I have to ask a favor. Could you start a new post with your question? We try to keep these specific to one type of vehicle and problem so that it is more helpful to others. I hope you understand.
Gere us the link to start a new thread. Just copy and paste your question and one of us will get you what is needed.
Again, I hope you understand.
Jun 16, 2023 at 1:27 PM
CAREYTOURAILLE
  • 5 POSTS
There was nothing wrong with the pump, it just needed to be run around. Then we filled the tank and now it's working.
Thanks for your help.
Jun 17, 2023 at 12:48 AM
  • 110,244 POSTS
Thank you for the update. That is the way to fix a problem. LOL I'm glad to know it's working for you.
Take care and feel free to come back anytime in the future.
Jun 17, 2023 at 3:20 PM
