Gas filter location
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JIMMY DOW
  • 5 POSTS
Idles funny. Wants to like lung when at a stop sign or light, when brakes are applied.
Oct 5, 2019 at 7:33 AM
Good afternoon,
I posted a picture below for you for the location.
It is under the car about the middle.
Oct 5, 2019 at 7:51 AM
JIMMY DOW
  • 5 POSTS
Really? I've been all over under that car. Hood to back bumper. I just cannot see it or find it. O'Riley's said it wasn't in the tank, but I am not sure. Out of places visible to look is that middle passenger side?
Oct 5, 2019 at 8:25 AM
JIMMY DOW
  • 5 POSTS
Only thing I can think is it is between the gas tank and floor boards. Drop the tank to find it?
Oct 5, 2019 at 8:26 AM
No, it is external and out in the open. It is a small can with 2 lines attached. Follow the lines from the tank.
Oct 5, 2019 at 8:28 AM
JIMMY DOW
  • 5 POSTS
Okay, I know what it looks like, i"'be followed the gas line from motor to tank runs under the par passenger side with two other lines . comes down from the motor strait under the body bends up and disappears over the top of the tank ... I see no filter .....
Oct 6, 2019 at 4:10 AM
JIMMY DOW
  • 5 POSTS
I mean it is a nice size can (filter) to see . You know
Oct 6, 2019 at 4:13 AM
If there is none, then it is part of the fuel pump assembly.
Just to be sure, there is a charcoal canister at the tank on the drivers side. It shows in the picture I sent you that it is at or above it.
Oct 6, 2019 at 4:34 AM
