Not accelerating properly
200,000 MILES • TURBO • 2WD • MANUAL
MINKA
hi , i drive a manual and in 3rd gear going 50 my car didn't want to go faster. i put it in 2nd and when trying to accelerate nothing happened. i turned it off and on again then everything was normal. when this happened my car lost approximately 20L of fuel.
May 29, 2021 at 6:58 PM
Has this happened again? Also, how do you know that it lost 20 litres of fuel? That is a lot of fuel or did you lose 20L of gas mileage? Meaning you were getting 30L per mile and then you started getting 10?
I would not be so concerned with the lose of fuel mileage if that is what is was because that is just a calculation and it will be corrected as soon as it doesn't see this issue happen again.
However, the lack of acceleration sounds like a fuel issue so I would suggest starting with checking for codes.
Then we need to remove the spark plugs and take a look at them to see if they can give any signs of what may be happening.
Below is a chart of what plugs look like based on different issues. However, if this only happened once and has not happened since, it is going to be difficult to determine what happened.
Let's run through this info and let us know if you have any codes and we can go from there. Thanks
May 30, 2021 at 10:31 AM
MINKA
no, it only happened once that time. i saw the line on the gas gauge go down quite a lot. i will be seeing the mechanic soon. thank you for your reply. :)
May 30, 2021 at 7:19 PM
Okay. Thanks for the update. Please keep us updated on what they find. Unfortunately there is not a common issue that would cause this so it may just be an electrical glitch that won't reoccur.
Thanks.
Jun 1, 2021 at 10:32 AM
