gas in the reservoir
265,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHN FURTADO
I put an ounce or two of gas accidently into oil reservoir does this damage car.
May 3, 2022 at 5:47 AM
  • 110,244 POSTS
If it was only an ounce or two, it shouldn't hurt. However, I would still recommend draining and replacing the oil. The fuel can think oil causing issues which can cause internal problems.
Here is a link you may find helpful. It explains how to change the engine oil and filter.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Let me know if this helps.
May 3, 2022 at 1:25 PM
