could you please advice me which type of oil for automatic gar box can I used related my car?
thanks a lot
Nov 21, 2016 at 7:18 PM
HMAC300
✓Experienced Mechanic
auto trans fluid DIAMOND SPIII for transmission or any brand meeting that requirement for transfer case Shell spirax ax or equivalent or api GL-5 or higher or equivalent. these will be marked on can or any auto parts can look it up and tell you what you need. it .8L for Tcase fill and if changing auto trans fluid probably about four quarts will do as capacity is 7.8L.
