Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Sentra
Engine
Computer
ECU pinout or wiring diagram needed
1993 NISSAN SENTRA
123,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
SALMUEL CARTER
MEMBER
1 POST
Is there a ECU pinout or wiring diagram for my car with a 1.6l ga16de? thank you
Jan 18, 2017 at 4:17 AM
HMAC300
Experienced Mechanic
yes, but are way too big to post on here. i will send where 16 pin is it is an orange wire that goes to air flow meter. See picture.
Image (Click to enlarge)
Jan 18, 2017 at 4:40 AM
SANJAY KOOLKID GREEN
MEMBER
1 POST
can you send me ecu pin out for ga16
Jan 13, 2019 at 6:50 AM
SCGRANTURISMO
Here is your ECU pinout and expected voltages. Hope this helps.
Thank you for using 2CarPros.com.
Jan 13, 2019 at 6:27 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
