Will not start, where is the fusible link located?
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JECCARULE10
The car will not start. Cranks but doesn’t start. We replaced a new starter and nothing.
May 27, 2023 at 8:09 AM
AL514
  • 5,700 POSTS
Hello, you say the vehicle cranks over, so the engine is turning over but won't start, is that correct? There can be many causes of a crank no start situation. The first easiest thing to check is if there is Ignition Spark. If there is spark out of one of the spark plug wires or ignition coils, then checking for Fuel pressure would be next. Do you notice anything else odd, does the Check engine light come on if the key is turned to the On/Run position? It should come on for a few seconds
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
May 28, 2023 at 10:47 AM
