key fob not working?
1,000,000 MILES • V8 • 4WD • AUTOMATIC
CHAD CROWDER
needing to know where the fuses are for the key-less entry.
Aug 14, 2019 at 10:45 AM
94 TRANSAM
  • 680 POSTS
Hi Chad, thank you for using 2CarPros. Here is the fuse location is it because your key fob isn't working? This guide will help check the fuse with the fuse ( #14 and #18) location in the diagrams below.
Check out the diagrams (Below). Please run this test and get back to us.
Rich
Sep 11, 2020 at 6:17 AM
CHAD CROWDER
Yes, key fobs are not working.
Sep 11, 2020 at 6:18 AM
94 TRANSAM
  • 680 POSTS
Try this reset procedure:
Start the vehicle and let it run for 2 minutes.
Then hold the lock and unlock buttons on the fob for 3 seconds then let the buttons up. Repeat this 3 times and that should reset them after a battery change etc.
Let me know how it turns out.
CHAD CROWDER
It did not work.
94 TRANSAM
  • 680 POSTS
Okay, It was worth a shot. May I ask if anything happened that may have made them stop working? Battery change, battery went dead, etc?
Here is the wiring diagram for the key-less circuit. This circuit is on an auto reset circuit breaker so if nothing happened I would test for voltage on both sides of the breaker to make sure it is good. It should be located in the fuse box under the hood.
Let me know what you find, Rich
