Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Suburban
General
Fuse Test
Fuses
1996 CHEVROLET SUBURBAN
25,849 MILES
JARROD379
MEMBER
Do I have s 30amp fuse for my stopping and brake lights in the fuse panel under the hood of my SUV?
Jun 26, 2019 at 8:39 AM
Experienced Mechanic
Good evening,
No, that circuit only uses a 15 amp fuse. Do not install a larger fuse.
Images (Click to enlarge)
Jun 26, 2019 at 8:46 AM
JARROD379
MEMBER
It that the fuse panel under the dashboard or in the engine bay?
Jun 26, 2019 at 8:50 AM
It is under the dash inside the car.
Jun 26, 2019 at 9:01 AM
JARROD379
MEMBER
Ya, I just replaced it with a new one that the same as the one I took out. I’m still not getting any brake lights.
Jun 26, 2019 at 9:04 AM
Okay, Did you test for power at the fuse with a test light or voltmeter?
You need to start there and then go to the switch on the pedal.
Image (Click to enlarge)
Jun 26, 2019 at 9:40 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
