Fuses
198,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DENISE LYNN PARSONS
My cigarette lighter has not worked in some time. I decided the other day to try and track down the fuse to replace it. I did not think I moved any others. After that my clock and tripometer would reset every time I start the car. I figured out that fuse but now my car will start but the gear shifter and button will not move. Traction control light was on as well.
Aug 21, 2018 at 8:42 PM
  • 55,721 POSTS
Did you remove any other fuses besides the cigarette fuse? It sounds like the battery could be causing the issue. Here is a guide to help you load test the battery:
Cheers, Ken
Aug 23, 2018 at 3:56 AM
