Passenger side window will no roll down
155,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
T. BROWN
My passenger side window will no roll down. The switch on the door was broke so I replaced it and still does no roll down. Cannot for the life of me find the window fuses. Where is the interior fuse panel the IPM under the hood? It does not have window fuses or anything.
Sep 27, 2018 at 9:08 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
On the left kick panel I did find a power window circuit breaker. I have attached a picture.You might want to check all the wiring harnesses for good connections and also check all the ground wires. I have also attached a few tutorials for you to view. Hope this helps and thanks for using 2Carpros.
Danny-
https://www.2carpros.com/articles/how-a-car-electrical-system-works
Sep 27, 2018 at 9:25 AM
T. BROWN
Thanks Danny. I will give this a whirl. I would probably find the kanooter valve before I can get the windows down.
Sep 27, 2018 at 9:28 AM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, keep me updated if you have any other questions.Thanks again for using 2CarPros.
Danny-
Sep 27, 2018 at 10:08 AM
