Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Electrical
Alternator
Fuse
Alternator fuses location
1990 TOYOTA CAMRY
180,000 MILES • 2.0L • 4 CYL • AUTOMATIC
VISECT1
MEMBER
1 POST
where is the alternator fuse located?
Jun 21, 2019 at 4:36 AM
Experienced Mechanic
Good afternoon,
There are three. I attached a diagram and circled the fuses for you and the location is identified.
Image (Click to enlarge)
Jun 21, 2019 at 5:07 AM
STEVE W.
Welcome to 2CarPros. There are replaceable fusible links in the system. The main link is in a box nest to the battery. That is an 80 amp part. Then in the line to the alternator there is another fuse link that can fail.
Jun 21, 2019 at 5:16 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
