The gears work but when I step on the accelerator it does not move.
Aug 31, 2021 at 6:45 PM
SQM
✓Experienced Mechanic
So you can put in drive but it does not move?
When you go from part to drive can you hear or feel the transmission engaging?
Sep 1, 2021 at 12:02 AM
MARY BONSU
MEMBER
Yes please.
Sep 1, 2021 at 1:29 AM
SQM
So when you put it in drive you can feel the transmission engaging? Does it engage in reverse?
Sep 2, 2021 at 12:01 AM
MARY BONSU
MEMBER
It does not reverse but not move at all.
Sep 2, 2021 at 6:34 PM
MARY BONSU
MEMBER
The engine start but when put in drive the sound doesn’t come and can’t move.
Sep 2, 2021 at 6:47 PM
SQM
It sounds like you could have an issue with the transmission control solenoid. Also could be an issue with the torque converter. As it is not engaging when you put it in gear.
There is a transmission position sensor located on the transmission if it get disconnected or loose it can also prevent the vehicle from going into gear.
Image (Click to enlarge)
Sep 3, 2021 at 12:45 AM
MARY BONSU
MEMBER
They put machine on it and tell them that it bbt sensor. would it be that?
Sep 6, 2021 at 4:20 AM
MARY BONSU
MEMBER
Sorry, I mean vvt sensor.
Sep 6, 2021 at 4:21 AM
MARY BONSU
MEMBER
Thanks.
Sep 7, 2021 at 1:50 AM
SQM
The VVT sensor is the variable valve timing sensor. Which is part of the engine management system.
Can you verify the engine size of your Nissan. You noted as a 4 cylinder. what model is it?
Xtera X trail?
I will take a deep dive after you verify the model and engine size.
Sep 8, 2021 at 12:25 AM
MARY BONSU
MEMBER
We change the VVT sensor and now it moving, everything is fine now. thank you very much for your support and guidelines.
Sep 8, 2021 at 7:27 AM
SQM
That's great news!
So glad you got it fixed.
Should you have any questions in the future feel free to reach out.
Sep 8, 2021 at 7:50 AM
MARY BONSU
MEMBER
Recently I changed the engine but when I move the car and the engine gets heated and I stop and start the car again it won’t start all. but when I wait about an hour it starts. so please help me. thanks
Oct 12, 2021 at 12:57 AM
SQM
Hello, it sounds like a cooling system issue. Since this is a new question, please open a new thread so that it can help the next person who could have the same issue.
Just go to this link:
