Fuse location for stereo needed?
110,000 MILES
BARTHOLOMEW2173
  • 6 POSTS
I am looking for a fuse that may be for my amp because i am getting absolutely no sound.
Aug 1, 2023 at 8:19 PM
  • 110,248 POSTS
If this has a factory amp, the fuse for it is fuse 16 in the under-hood fuse box. It is a 40-amp fuse. See pic below
When you check this, also confirm there is power to and from it.
Pics 2 and 3 show the fuse in question and fuse box location.
Let me know what you find or if you have questions.
See pic below.
Aug 2, 2023 at 1:45 PM
BARTHOLOMEW2173
  • 6 POSTS
This was perfect and accurate, but i am still having the issue that i have no sound to my vehicle. i do have an aftermarket radio but it was working fine until i tried to hook up my backup cam and still failed and after the sound disappeared. if anyone knows the problem, please let me know.
Aug 2, 2023 at 8:03 PM
  • 110,248 POSTS
Does the radio turn on? Did you check if there is power to the amp itself? As far as the backup camera, where did you get power from and where did you get a ground?
Aug 3, 2023 at 1:12 PM
BARTHOLOMEW2173
  • 6 POSTS
For the backup camera i am trying to re-use my backup camera that is built into the vehicle.
Aug 3, 2023 at 6:19 PM
BARTHOLOMEW2173
  • 6 POSTS
So I'm just trying to figure out how to connect it using what's there.
Aug 3, 2023 at 6:20 PM
  • 110,248 POSTS
That is going to drive you crazy. There are so many wires related to the OEM design. What I would suggest is to simply gain power via a backup light bulb. When you place the vehicle in reverse, the backup lamps turn on which will power the unit. At least that is how I've seen them done on other vehicles.
By chance, do you have the wiring schematic for the new one? If so, could you upload it so I can see what they are recommending?
Aug 4, 2023 at 1:06 PM
BARTHOLOMEW2173
  • 6 POSTS
I'm not trying to use the new camera I'm trying to reuse the backup camera that is built into the car with the aftermarket radio if i need to send pictures of anything in specific that will help with configuring that let me know.
Aug 4, 2023 at 7:15 PM
  • 110,248 POSTS
I understand now. LOL Here is the thing. Without being there to study the new radio schematic, I'm not sure I can help. If possible, upload the schematic that came with the radio, and I'll see if I can help.
Aug 5, 2023 at 8:34 AM
