Where is the parking brake fuse located?
111,111 MILES • V12 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
The vehicle is 760Li but I couldn't find it on the options.
The vehicle will make a loud noise whenever the parking brake button is pressed. I need to check the fuse to the parking brake. Please could I get the location to the parking brake fuse.
The following codes display when scanned under the ABS-DSC : 1. 4806CF : parking brake cannot execute control command.
2. 48096E : EMF : Emergency release
3: 480A62 : EMF : Brake cannot be released.
The following codes were found in the EMF (parking Brake)
1. 48051A : Actuating unit: emergency release
2. 48052C : Actuating unit: cable crack.
I really appreciate your effort so far.
Feb 27, 2024 at 2:34 AM
  • 110,246 POSTS
Hi:
I attached two pics below. They are a side by side view. I highlighted the fuse.
What noise are you hearing and can you tell where it is coming from? It sounds like someone damaged the worm gear in the PB actuator. Also, can you provide me with P codes? I not finding any of the ones listed above under the manufacturer's code list.
See pics below
Feb 27, 2024 at 10:27 AM
BLESSING EWOBOR
  • 753 POSTS
Where exactly are they located, is it in! He front fuse box, rear or where exactly?
Feb 27, 2024 at 11:55 AM
  • 110,246 POSTS
I attached what the manual is showing me. Let me know if it helps.
Feb 28, 2024 at 10:13 AM
BLESSING EWOBOR
  • 753 POSTS
Mar 2, 2024 at 10:54 AM
