Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Maxima
Electrical
Fuse Panel
Location
Fuse location
1996 NISSAN MAXIMA
223,000 MILES • 0.5L • 4 CYL • FWD • AUTOMATIC
DAVID SEARCY2
MEMBER
Where the fuse for washer fluid? it does not work but wipers do. i have no manual.
Apr 16, 2017 at 3:03 AM
HMAC300
Experienced Mechanic
they use the same fuse so the motor or switch is probably bad if you can see if power is coming to motor that would eliminate the switch.
Apr 16, 2017 at 4:59 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
