Fuse location
1996 NISSAN MAXIMA
223,000 MILES • 0.5L • 4 CYL • FWD • AUTOMATIC
DAVID SEARCY2
Where the fuse for washer fluid? it does not work but wipers do. i have no manual.
Apr 16, 2017 at 3:03 AM
HMAC300
  • 48,601 POSTS
they use the same fuse so the motor or switch is probably bad if you can see if power is coming to motor that would eliminate the switch.
Apr 16, 2017 at 4:59 AM
